Skrivet av: Kalle72
« skrivet: 20 augusti 2010, 12:17:23 »Yes, can you please do that so I know where to start.
Skrivet av: Kalle72« skrivet: 20 augusti 2010, 12:17:23 »Yes, can you please do that so I know where to start.
Skrivet av: fulda« skrivet: 18 augusti 2010, 13:31:21 »It seems to work better with a fan, i will test more later this week. If you want a play, I can describe you which rezistors can be changed to you. Skrivet av: Kalle72« skrivet: 12 augusti 2010, 22:00:03 »It seems to work better with a fan, i will test more later this week.
So, it probably was a heat problem in the end... Skrivet av: fulda« skrivet: 11 augusti 2010, 10:34:06 »I have 5,06V between red and blue wires when i measure so it seems to be ok. 5,06V is OK, every voltage between 4,5-5,5 is same = it will not you if you will have 5.5V One strange thing is that when i unplug the dsub from the rego and reconnect it again it works without any errors for 15-20min, then it starts over again with errors every 4-5min... sounds like a problem with temperature of interface. There is nothing "to be reseted". Try to done two things: 1) try to play with fan cooler 2) check my schematics on Fig.1 is the IVT@Home - you can play with capacitors and resistors. (or non-schematics in FAQ) Skrivet av: Kalle72« skrivet: 10 augusti 2010, 21:12:19 »Thank you for your Fulda.
I have 5,06V between red and blue wires when i measure so it seems to be ok. Is there anything i can measure on the other side of the adapter, towards the rego? Or shuld i try to connect an external supply and tune it in to 5,5V to see if it helps? One strange thing is that when i unplug the dsub from the rego and reconnect it again it works without any errors for 15-20min, then it starts over again with errors every 4-5min... As if the rego "restarts" or so, i have Rego637 with sw 3.06. Skrivet av: fulda« skrivet: 10 augusti 2010, 09:50:51 »Men, efter att jag skruvat på alla plåtar igen så började fel-loggen fyllas med "timeouts", och inte några heller. Hi Kalle, Hakke, 2 answers in 1 post Kalle: I have little problem to understand your message - you are using many words which google translator not know. If I understand you right, you have original StatLink (IVT@Home) and you are added 4m of cable to your interface? Usual problem of original interface is powering. Have you some voltmeter you can measure voltage between red and blue wires on interface. (see picture). It must be 4,5 to 5.5V otherwise you will have problem. Usual solution is to buy some chaep "USB charger" and use it as 5V source, connect original USB cable to it (you must connect blue cable from interface to black cable from USB) and keep it close of heatpump. For computer serial port use only 3 wires - yellow, black and blue (conected to pins 2,3 and 5 of serial port). Hakke: I have found same problem on one heatpump and found, that it sometime happens depend on manufacturer of MAX232. Somebody have different recommendet values of capacitors and it sometime making a problems. Now I know 2 possible solutions - one is to play with resistors (you done) and second is to read original datasheet for your version of MAX232 on vendor page and change capacitors Skrivet av: Håkke« skrivet: 10 augusti 2010, 08:42:21 »Det kostar väl en satans massa pengar att köpa detta från IVT så reklamera produkten om den krånglar. Konstigt att RS 232 kabeln var så kort att du måste förlänga den, jag har nog c 15 m till min laptop.
Kolla som sagt hur kurvorna ser ut, har du inga konstiga avvikelser så kan du nog köra ett tag. Det blir ju varmare inne i vp framåt hösten-vintern och då kanske det blir mer problem? Skrivet av: Kalle72« skrivet: 09 augusti 2010, 20:42:00 »Förlängningen är på datorsidan så det ska vara ok.
Så som jag har det nu utan huv etc och med kabeln i princip vinkelrät ut från pumpen för att få minimal påverkan så får jag en timeout var 5-6 minut och det kanske är ok för själva loggningen men jag vill ju gärna ha huven på för att minska ljudnivån när pumpen är igång. Kan ju inte vara meningen att det ska vara så här känsligt..kanske har fått ett "måndagsexemplar" av adaptern... Finns det något sätt att kontrollera om den lämnar rätt nivåer? Kan man mäta upp den på något sätt tro? Tack för svaren, jag ska skicka ett PM till Fulda. Skrivet av: Håkke« skrivet: 09 augusti 2010, 19:40:08 »Har haft liknande problem med ett hemgjort interface och annan programvara. Fick ibland konstiga värden och det verkar som temperaturen inne i vp påverkar eftersom jag fick mindre problem då jag tog bort frontplåten. Jag labbade lite med interfacets motstånd och fick till slut till en lösning som funkar hyfsat oavsett monterad front eller inte.
Vad jag förstår så loggar Statlink varannan minut (?) och det kanske inte spelar någon roll om du får några timeouts. Ser du några konstiga språng i kurvorna? Om inte tror jag att du kan leva med problemet. Du talar om förlängd kabel? Har du förlängt den som är mellan service uttaget intill Rego och själva adaptern? Den får inte vara längre än 10-20 cm, mycket känsligt! Jag har c 10 cm. På RS-232 sidan mot datornär det inga problem att förlänga "Fulda" kan det mesta om Rego 6xx kommunikation , kanske du kan skicka ett PM till honom och fråga. Skrivet av: Kalle72« skrivet: 09 augusti 2010, 18:19:44 »Hej alla glada experter!
Jag har sedan ca en månad tillbaka en IVT Greenline E6 installerad och till den ett fint 110m borrhål. Då jag är intresserad av att få anläggningen att fungera så optimalt jag nu förmår så köpte jag till StatLink. För ett par dagar sedan fick jag tid att börja labba med programmet, det riktigt kliade i fingrarna :-) Spänd av förväntan kopplade jag ihop allt och till en början verkade allt flyta på (som jag då trodde) bra. Men, efter att jag skruvat på alla plåtar igen så började fel-loggen fyllas med "timeouts", och inte några heller. Min första tanke var att jag klämt kabeln eller att jag misslyckats med förlängningen av kabeln (orginal var den ju för kort). Så bort med alla plåtar, kontroll av "skarvarna", osv, och då började felen minska. Så här ser loggen ut just nu utan plåtar: ERROR:2010-08-09 17:36:51 Src:RegoComm-ReadIn, Timeout on three requests to Rego6xx. Retrying... ERROR:2010-08-09 17:47:52 Src:RegoComm-ReadIn, Timeout on three requests to Rego6xx. Retrying... ERROR:2010-08-09 17:51:59 Src:RegoComm-ReadIn, Timeout on three requests to Rego6xx. Retrying... ERROR:2010-08-09 17:53:31 Src:RegoComm-ReadIn, Timeout on three requests to Rego6xx. Retrying... ERROR:2010-08-09 17:55:50 Src:RegoComm-ReadIn, Timeout on three requests to Rego6xx. Retrying... När jag körde med alla plåtar/huv så var det ca 2 fel i minuten! Jag kör windows 7 med statlink 3.1.0 Portinställningar 19200 8N1 Orginaladapter, påskarvad med ca 4meter ELLXB (4x0,5) från Kjell&Co, skarvarna lödda. Är det någon som har haft liknande problem och kan ge mig något tips om vad som felar?! -är den påskarvade kabeln för klen? -vad är det som stör "mest" inne i pumpen och som man ska undvika dra kabeln för nära? |
